Job Importer User Role
Fast, Accurate Job Creation—Without Extra Risk
The Job Importer user role is designed for team members responsible for creating new jobs at scale and populating them with subject data and images inside Captura Workflow, the heart of the Captura connected ecosystem.
This role is intentionally narrow and purpose-built. It enables speed and accuracy during bulk setup—without granting unnecessary access to pricing, orders, or administrative settings.
Why this matters
Job imports are often the first step in a season. Getting them right—and limiting access to just what’s required—prevents downstream errors and rework.
Permission Philosophy for Job Importer User Roles
Job Importers need enough access to:
  • Create job shells
  • Bring subject data and images into Workflow
They should not manage job configuration, pricing, storefronts, or orders.
This role is about input, not decision-making.
1. Job Creation (Required)
Job Importer → Import & Create Jobs → Add / Edit / Delete
Allows users to:
  • Generate new jobs via the import process
  • Create job shells programmatically or in bulk
Why this matters
Without this permission, users can upload files—but can’t actually create the jobs they belong to.
2. Import Tool Access
Creating the job isn’t enough—the user also needs access to the import tools inside the job.
Capture → Tools — Import → View (On)
Allows users to:
  • Access the Import tool while inside a job
  • Import subject data and images
Why this matters
This toggle activates the tool itself. Without it, imports can’t be executed—even if other permissions are set correctly.
3. Data & Image Write Access
To save imported files, the user must be allowed to write data into Workflow.
Capture → Subject Data → Add / Edit
Allows users to:
  • Create new subject records
  • Populate jobs with imported student or participant lists
Why this matters
Imports fail silently if users can’t write subject data.
Capture → Images → Add / Edit
Allows users to:
  • Add images to subjects
  • Save imported photo files
Why this matters
Image imports require explicit write access—view-only permissions aren’t enough.
Job Importer User Role Summary
Section
Feature
Recommended Setting
What This Enables
Job Importer
Add / Edit / Delete
Create new jobs
