Download Captura Workflow and Workflow Lab
To download the Captura Workflow application, choose the Installer that matches your computer Operating System (OS) below:
Operating System
Download
Windows 11 (64-bit)
Windows 10 (64-bit)
Download for Windows
macOS 13 Ventura or newer**
Download for Mac
Captura Workflow Lab
Operating System
Download
Windows 11 (64-bit)
Windows 10 (64-bit)
Download for Mac
*Windows 32-bit systems are not supported.
**Macs built in 2010 or earlier are not supported.
Installing updates
Workflow will receive automatic updates outside of the Fall season. Click "UPDATE NOW" when prompted to start the update.
Select "Later" for Workflow to update the next time you close the app.
For IT Professionals
For Workflow to run on a domain-controlled workstation and/or on a managed network, the following must be done:
  • Ensuring network traffic for *api.imagequix.com is approved on the network.
  • Allowing Registry Edit access for the user account to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\806c13e0-1bb7-5fc0-b1ef-6593ede2ca5e
Note: You may only see a white screen in-app if either of the above is not done.
Start a chat with us if further assistance is needed.
Workflow needs access to modify the registry at that path when running with a computer user account, as the app will make changes during installation and updates.
Minimum device requirements
  • Intel i5 8th Generation Processor (or equivalent)
  • 8GB DDR3 RAM
  • 128GB SSD
  • 1300x900 display
