Price Sheets: Packages
What is a Package?
A package is a container that you can add different products and image options into. There are two types of packages:
Standard - where everything inside of the package is included for a base price.
Build your own - customers pick a set amount from everything inside the package.
Packages have an additional feature to set a limit on the number of images or allowing for more images than normal through a surcharge.
Adding packages
Inside a price sheet, select a category in the menu and click Add Package. From here, you can select the package to add products or edit settings.
π’ Use packages only when you include more than 1 item with the purchase.
Display Image
π’ βRecommend Use a 600x600px image for the best fit online.
Name
Set the name to apply to the package (or item) on your price sheet. Whatever is set here is shown online in the shop.
Price
Set the price to apply to the package (or item) on your price sheet. Whatever is set here is shown online in the shop.
βWarning Having trouble setting the price to $0? Send us a message for help!
Set the description to apply to the package (or item) on your price sheet. Whatever is set here is shown online in the shop.
π Note:
Do not enter package contents. That is already listed automatically.
Ref. ID
Set the reference ID for order data and exports. Mainly used for fulfillment with vertical studio workflows.
Package Type
Choose between the default standard or build your own as a package type
Build Your Own Packages
When using a build your own package, there are a few additional changes to make:
Set both a minimum and maximum value for customers to complete their package.
There's a new item value for the products and options inside of the package.
Set higher values for higher-cost products and limit the number of selections.
Optionally set certain products to be included in the package.
Apply a custom label to the products in the BYOP (try calling them prints, sheets, etc.)
Image Configuration
Set how many images are included in the package. The default is 1 image per package. Customers could purchase additional images for a per-image or one-time fee. Packages can also allow for unlimited number of images.
π’ Opportunities to leverage number of images in a package to increase AOV
Visibility
Set if the item is visible in the shop or not.
π Note:
Hide all items in a category to hide the entire category from the shop.
Smart Workflow users will be able to place in-app orders with hidden items.
Get a head-start on building out any holiday pricing.
Then unhide when the time comes!
Discount Code
Attach a Based-On Order (BOO) discount code to a package or product. This item, when purchased, generates a discount code for the next order on the subject gallery.
