Price Sheets: Product-Specific Shipping & Exemptions
What are Product-Specific Shipping & Exemptions?
Product-specific shipping and exemptions give you more fine-tuned control on shipping costs. You may include additional shipping costs for products that are more expensive to ship, such as a heavy or oversized item. You may also exclude shipping for products, such as yearbook photo retouching, to avoid charging shipping when that is the only item ordered. You can make these adjustments per product, package and/or collection in each price sheet, giving you flexibility to add to the cart-level shipping fees for certain items or to set shipping exemptions for products that incur no shipping if they are the only type of product purchased.
📢 Digital-download only orders still do not incur shipping.
📝 To use this feature, make sure you've installed the Captura Workflow version Latest Releases. This can be found by navigating to Preferences > Advanced.
Adding Product-Specific Shipping & Exemptions
Inside a price sheet, select a print product, non-print product, package, or collection to edit. Under Shipping, you can select from the following options:
Default - Applying Shipping Rate in Shopping Cart Settings
No Cost - This item is except from Shipping Rate in Shopping Cart Settings
Additional Cost - Additional cost added to Shipping Rate in Shopping Cart Settings
When selected, the Additional Shipping Cost is visible so you can set the amount of additional shipping to apply.
📢 For packages, you can only select the shipping at the package level, not for the products within the package.
So how is shipping calculated?
Shipping is still calculated in the cart during checkout, and customers will only see their total shipping cost. For example, if they purchase an item with additional shipping cost, they will see that already added to the cart default shipping.
Let’s walk through some examples.
Example #1
The shopping cart template’s shipping is $6, and the studio configured additional cost items on their price sheet.
Cart
8x10 Print (default shipping of $6)
Coffee Mug (using additional cost shipping of $10)
Metal Print (using additional cost shipping of $15)
Shipping Total: $31
Shipping Explanation: Since the customer purchased an 8x10, which uses the cart’s default shipping of $6 and two items that incur additional costs of $10 and $15, the shipping total is $6 + $10 + $15 = $31.
Example #2
The shopping cart template’s shipping is $6, and the studio configured no cost items on their price sheet.
Cart
Yearbook Image Retouching (using no cost shipping)
Shipping Total: $6
Shipping Explanation: Since the customer purchased an 8x10, which uses the cart’s default shipping of $6 and yearbook retouching, which incurs no shipping, the total is $6.
Example #3
Cart
Shipping Total: $0
Shipping Explanation: Since the customer only purchased a no cost shipping item, the shipping total is $0.
Example #4
Cart
5x7 Print previously mailed to the customer in a Spec Package (using no cost shipping)
Shipping Total: $0
Shipping Explanation: Since the customer only purchased no cost shipping items, the shipping total is $0.
Example #5
The shopping cart template’s shipping is $6, the studio configured additional cost items on their price sheet, and the customer has a discount code for 100% free shipping.
Cart
8x10 (default shipping of $6)
Shipping Total: $0
Shipping Explanation: Since the customer has a discount code for 100% free shipping, the shipping total is $0.
