Editing Images
Click on the Edit button in the top-left corner next to the image count to switch from Review mode to Edit mode.
Navigate editing tools by selecting the tabs located on the far-left pane of the screen.
Color
Make manual adjustments to the brightness, contrast, hue, saturation, and color balance of images.
Crop
Crop images based on inputting x and y coordinates and zoom.
Head Size
Automatically apply a crop based on head size using facial detection of features.
AI Image Editing
Suite of AI pre-touch image editing features including AI Crop, AI Color Correction, AI Background Extraction, AI Face Retouching, AI Glass Glare Removal, AI Teeth Whitening, and AI Braces Removal.
Learn more about these features here.
Applying Changes
In the subsequent pane, you can indicate whether the edits should be applied to a single image, a filtered image set (if applicable), or all images.
Click on the apply button to apply the edits. Use the reset button on Color, Crop, or Head Size if you made a mistake and need to remove edits and restore the original version.
During the image editing process, utilize the toolbar at the bottom of the central pane to activate guidelines, implement standard crops, or display the image file name. Additionally, you can click and drag to manually position the image according to your preferences.
Download and Replace Images
Utilize the download and replace features to export images from Workflow for editing with external tools or software such as Adobe Photoshop.
After completing your edits, simply click the Replace button to effortlessly substitute the relevant images in the job with your edited versions. In this situation, we recommend preserving your images as the optimal choice.
Pro Tip: Please be aware that the replace feature operates by aligning the image filename in Workflow with the file name in the folder housing the replacement images. If Workflow cannot locate the corresponding image filename in the job, it will bypass the image in the folder.
