Custom Forms: School pre-order
Here's an example of what we'd recommend a good underclass form would look like:
📝 Considerthe following from the example above:
First Name and Last Name are customized to ask for the student'sname.
Fields are marked required to be completed before checkout.
Using Dropdown: Selectinstead of the pre-provided Grade text field.
Pre-defined selections help eliminate data formatting issues.
Email and Phone data are collected for marketing or support purposes. *
*requires adding form data to subject data during pre-order assignment
