Products: Proof Sheets
Prints in My Designs refers to products that:
  • has a unique image grid layer that requires at least 1 node.
  • can be templated and customized.
These products are mostly used by the community to create things like:
  • Cards (Trader, IDs, Holiday, etc.)
  • Memory Mates
  • Personalized Prints
and are typically set to be fulfilled on print units offered by lab services or attached to jobs as print templates. *
*job print templates require Smart Workflow
Create a new proof sheet product
Under My Designs, select Add Product → Proof Sheet.
📢 Notice the unique icon - A form to indicate that it's a proof sheet product.
Then customize the core settings of your new proof sheet product.
❗Warning requires a set size greater than 0 for width and height before syncing.
Display Image
​Recommend 600x600px image size.
Name
Pages
Set which page template type to use. Build a single template for all repeating pages or create a separate, unique template for the first page per subject.
The total image size of the product in inches.
📢 Recommend 8.5" by 11" for standard paper size
Set whether image grids span unlimited pages or if it is limited to a set number of pages. Unlimited pages is the default setting.
Price
Set the default price of the product. While it may be the default price, this attribute can always be changed on the price sheet.
Default of $0 is acceptable.
SKU
Set the SKU of the product for vertical lab workflows.
Billing Code
Set the billing code for advanced product billing referencing through order exports.
Set the default description of the product. While it may be the default description, this attribute can always be changed on the price sheet.
Create a custom print design
Under My Designs, select a proof sheet product and click Design.
The print designer is a photoshop-like tool that can mix data from different sources across 4 layers into a flattened image for a lab to fulfill.
Learn more
