Products: Prints
Prints in My Designs refers to products that:
  • require an image for fulfillment.
  • can be templated and customized.
These products are mostly used by the community to create things like:
  • Cards (Trader, IDs, Holiday, etc.)
  • Memory Mates
  • Personalized Prints
and are typically set to be fulfilled on print units offered by lab services or attached to a job as a print template.
*job print templates require Smart Workflow
Create a new print product
Under My Designs, select Add Product → Print
📢 Notice the unique icon - A picture frame to indicate that it's a print product.
Customize the core settings of your new print product:
❗Warning requires a set size greater than 0 for width and height before syncing.
Display Image
​Recommend 600x600px image size.
Name
Size (width and height in inches)
The total image size of the product in inches.
Price
Set the default price of the product. While it may be the default price, this attribute can always be changed on the price sheet.
Default of $0 is acceptable.
SKU
Set the SKU of the product. This setting is what links Captura Workflow orders to specific products and configurations in PLIC Lab for vertical studio fulfillment. While it may be the default SKU, this attribute can always be changed on the price sheet.
Billing Code
Set the billing code for advanced product billing referencing through order exports.
Set the default description of the product. While it may be the default description, this attribute can always be changed on the price sheet.
Print Rotation
Set if the print template should be rotated 90 degrees when printed with Job Tools. *
*only with Smart Workflow
Create a custom print design
Under My Designs, select a print product and click Design.
The print designer is a photoshop-like tool that can mix data from different sources across 4 layers into a flattened image for a lab to fulfill.
Learn more
