What are Product Options?
Product Options lets studios offer services to enhance or alter a self-fulfilled product before it's fulfilled. These options usually involve common scenarios like:
  • Purchasing a frame and selecting a style of frame.
  • Purchasing a session fee and toggling an interest in use of premium props.
  • Purchasing a yard sign design and capturing text to apply during fulfillment.
When ordered, Captura Workflow creates My Service orders the studio can use to manage the service's fulfillment outside of Captura Workflow.
Creating a new product option
Creating a category
Under My Designs, toggle to Options → Product Options, then select or create a category.
📝 Consider using categories for:
  • Product Types
  • Photography Event Types
If you don't plan on having multiple categories, we recommend creating one studio category - and keeping everything in there.
❗Warning:
  • You'll need at least 1 category before you can create a product option.
  • Sync to save the category before creating new products or services.
Creating a product option
Inside a product option category, select Add Option.
You can create 3 types of product options - a toggle or selection option:
  • Toggle - Yes/No checkbox for customers to opt-in for services.
  • Selection - for offering different levels of a service (Basic, Advanced retouching).
  • Text - To collect customer-entered text.
Captura Workflow supports 3 different option types:
  • Toggle
  • Selection
  • Text*
📝 Note: The text option is only available for product options.
Whether you're creating image, order, or product options, the types remain the same.
Learn more
​https://support.captura.io/en/categories/1564225-workflow
