What are Image Options?
Image Options, also known as Add-Ons in the Shop,let studios offer services to enhance or alter an image before it's fulfilled. These options usually involve common services like:
  • Retouching
  • Braces Removal
  • Teeth Whitening
  • Glass Glare Removal
My Service orders are completed by the studio under the Fulfillment tab of Captura Workflow. The platform intelligently queues these services to be completed in-between Skylab and Lab services - but this means nothing will print until all ordered image options are done.
Studios can leverage our AI Image Options to provide add-ons to their customers with ease. Learn more about AI Image Editing here.
📢 Remember Check the Fulfillment section of Captura Workflow regularly if implemented.
Creating a new image option
Creating a category
Under My Designs, toggle to Options → Image Options, then select or create a category.
📝 Consider using categories for:
  • Photography Type (School, Sports, etc.)
If you don't plan on having multiple categories, we recommend creating one studio category - and keeping everything in there.
❗Warning:
Image options are not suited for use in the following ways:
  • Adding text. (name/year personalization)
  • Adding layers. (graphics, banners, etc.)
  • Cropping images.
Additionally:
  • You'll need at least 1 category before you can create an image option.
  • Sync to save the category before creating new products or services.
Creating an image option
Inside an image option category, select Add Option.
You can create two types of image options - a toggle or selection option:
  • Toggle - Yes/No checkbox for customers to opt-in for services.
  • Selection - For users to select different levels of a service.
Captura Workflow supports 3 different option types:
  • Toggle
  • Selection
  • Text*
📝 Note: The text option is only available for product options.
Whether you're creating image, order, or product options, the types remain the same.
Learn more
