Options: Selection Option
A selection is a multi-level prompt for customers to addadditional services to their order. Customers choose the core option (Example: Retouching), then select the desired level of service for purchase (Example: Basic, Advanced, Superior)
Creating a selection option
In My Designs, select Options →(Image, Product, Order).
Then, when inside of a category, select Add Option → Selection
Settings
Name
The default name to apply to the core option when added to a price sheet. While it may be the default name, this attribute can always be changed on the price sheet.
Required or Optional
Specify whether this item is required to set by the customer or keep it optional.
Download Original Image
When enabled, have Captura Workflow provide the original version of the ordered image.
📝 Note: This is used for outdated low-quality extraction workflows to cut costs and effort on extracting images. Some enable this feature, upload fast + cheap low-quality knockouts, then have Captura Workflow fulfill orders starting with the original image to apply a higher-quality knockout.
Interested in that workflow? Send us a message to learn a better approach.
Selections
📝 Note:
You can add as many selections as needed to the core option.
The core option automatically includes a "no" option.
This cannot be removed at this time.
Just like other items, you can duplicate selections to speed up data entry.
Display Image
📢 Recommend: Use a 600x600px image for the best fit online.
Name
Set the default name to apply to the current selection of the core option when added to a price sheet. While it may be the default name, this attribute can always be changed on the price sheet.
Price
Set the default price of the item. While it may be the default price, this attribute can always be changed on the price sheet.
📝 Note: The $0 default pricing is acceptable.
SKU
Set the SKU of the item. While it may be the default SKU, this attribute can always be changed on the price sheet. Used for vertical studio workflows where applicable.
Ref. Number
Set the reference number for order data and exports. While it may be the default reference number, this attribute can always be changed on the price sheet. Mainly used for enterprise bookkeeping workflows.
Set the default description of the item. While it may be the default description, this attribute can always be changed on the price sheet.
