Options: Text Option
A text option is a textbox prompt for customers to collect text for item personalization.
Creating a text option
In My Designs, select Options →(Product).
📝 Note: The text option is only available for product options.
Then, when inside of a category, select Add Option → Toggle.
Display Image
📢 Recommend Use a 600x600px image for the best fit online.
Name
Price
Set the default price of the item. While it may be the default price, this attribute can always be changed on the price sheet.
📝 Note: The $0 default pricing is acceptable.
Required or Optional
Specify whether this item is required to set by the customer or keep it optional.
Set Max Characters
Set the maximum number of characters that this order option can contain up to 255.
Identification
Mainly used for vertical studio fulfillment workflows or enterprise bookkeeping workflows. The values of these items are included in the order data used for fulfillment and reporting.
SKU
Set the SKU of the item. While it may be the default SKU, this attribute can always be changed on the price sheet. Used for vertical studio workflows where applicable.
Ref. Number
Set the reference number for order data and exports. While it may be the default reference number, this attribute can always be changed on the price sheet.
Set the default description of the item. While it may be the default description, this attribute can always be changed on the price sheet.
Download Original Image
When enabled, have Captura Workflow provide the original version of the ordered image.
📝 Note: This is used for outdated low-quality extraction workflows to cut costs and effort on extracting images. Some enable this feature, upload fast + cheap low-quality knockouts, then have Captura Workflow fulfill orders starting with the original image to apply a higher-quality knockout.
Interested in that workflow? Send us a message to learn a better approach.
