Job Settings: Job Images
Customize ordered print products with job images.
The Job Images section of Job Settings is where the studio can upload images to be dynamically applied to My Design prints when ordered. Perfect for adding logos, foregrounds or other assets to a design template instead of specific, pre-built items.
Map an image node to Job Image 1-3 on a print or proof sheet product to have the corresponding image be dynamically applied.
📌 Note: Avoid making size differences between the image node and job images.
Keeping the aspect ratio and image size consistent prevents stretching/squishing issues when Captura Workflow renders the final image.
This feature is only available in The Shop.
