Job Settings: General Settings
The General section of Job Settings is where the studio can add generic settings like Keyword, Password, Reference, and attach a Custom Form for pre-order configurations.
This section also lets you adjust the "core" information to create a job, like:
  • Price Sheet
  • Cart Template
  • Configuration
  • etc.
If this was skipped during new job setup, the settings can always be applied at any time.
Inside a Job, open Job Settings → General
Along with changing the core settings to create the job, the unique general settings that can be set are:
Reference
Set a keyword to the job to make it more searchable.
Password
Set an additional, shared "gallery password" that every visitor will need in order to access the shop. During re-order.
Custom Form
Attach a custom form to the job. Select No Form to skip using a form for the job. You'll absolutely want to add a custom form if you're doing a pre-order job.
