Job Settings: Export Templates
The Export Templates section of Job Settings is where the studio can attach certain exports to the job for quick access. Users will always have access to all custom exports made by the studio.
📝 Consider the following: Newer studios will likely skip this step in their first year with Captura Workflow- but consider how many different export types the studio fulfills.
As the amount of saved custom exports grows, it becomes easier to attach the specific ones you need - for quick and easy access - and save yourself the trouble of scanning a long list.
If this was skipped during new job setup, the settings can always be applied at any time.
Inside a Job, open Job Settings → Schedule
Event Date
The date of the photoshoot.
Retake Date
The date of a retake photoshoot.
Expiration Date
Set the date and time access to the gallery should be expired. From the specified time onward, visitors will see the gallery expiration message from the cart template.
Custom Date 1
This custom date is used for marketing purposes - mainly as a trigger for email/SMS alerts.
Custom Date 2
