Import: Replace Images
Overwrite or preserve existing images while replacing them.
Import Method: Replace Images
This import method is used to replace existing images in the gallery with edited versions by comparing the original image filenames in the Job with your edited versions. If Captura Workflow finds a match, it can add to or overwrite the existing images
Replacing original images with retouched versions.
Replacing green screen JPG images with knocked-out PNG versions.
In the Import tool, click on Replace Images:
Then choose the folder that contains the new images and your versioning preference:
Step 1: Select the folder that contains your edited images
These images must have the same filename as the originals in Captura Workflow during your editing workflow.
Step 2: Select your version control
Specify if you want to preserve or overwrite existing images:
Preserve: Replace and keep original images. (Defaulted)
Overwrite: Remove and replace original images.
**We always recommend preserving images in your Job 💯**
