Import: Auto-Categorize by Folder
Automatically create groups from a collection of folders and images.
Import Method: Collection of folders and images (Groups)
This import method uses a sub-folder organizational structure to import data and images. Your sub-folders will be added in as Groups (using the folder names as group names). The images inside the sub-folders will be automatically assigned to their corresponding groups.
In the Import tool, click on Auto-Categorize by Folder:
Step 1: Import Data
Select the root folder that contains the sub-folders you want to import as groups.
Specify if the import should include images inside of the sub-folders
Step 2: You're Ready to Import
Review the selections you've made and make any final edits before starting the import
