Exporting Photographer Reports
In a Job, open the Subjects tab and apply a desired filter, such as:
Subjects without images
Images from a specific camera serial-number or date-range.
With the desired filter applied, select Export List at the bottom of the screen.
Set where Captura Worflow should export the list and the folder name it'll put the output in.
📝 Note: You can save your applied filter to the device for quick access in any job.
