Getting Started: Import and Organize
Jobs are critical to any studio's day-to-day activity with Captura Workflow.
💡 Think of Jobs as folders with all subjects, images, and orders for a photoshoot.
This is where the real work gets done, like:
  • Creating and managing subject data.
  • Exporting photoshoot materials like Barcodes, QR Codes, Photog Reports, etc.
  • Preparing workstations for template printing and tethered capture. *
  • Sorting, reviewing, and editing images. *
  • Exporting service exports like Admin CDs, PSPA, PowerSchool, Yearbook CDs, etc.
  • Managing and releasing orders for fulfillment.
📝 Note: *Only with Smart Workflow.
In this module, you'll need to have the following completed before moving on:
  1. Jobs
    1. Create a new job.
    2. Apply the right settings for success with the job.
    3. Import subject data.
    4. Merge or group subject data.
Start
Creating a job
Captura Workflow is a cloud-based solution - meaning all users interact with a local copy of a job on their device, then sync their changes back to the cloud for Captura Workflow to merge in.
Captura Workflow's New Job Setup tool breaks up creating a job into sections, with the optional sections available to be set or changed at any point after the job's been created.
Learn more
Preparing a Job
Use our collection of typical job setups the community uses every day with Captura Workflow.
Learn more
📢 Remember:
  • Nearly any setting can be changed or modified after the job's creation, but it's crucial to get all settings properly applied before picture day or taking orders.
  • It can be intimating trying to pick the right settings at first, that's why we've prepared the collection above to help get started with typical job setups.
  • Send us a message with any questions about your job's unique needs!
Importing Data
Inside of a job, use the import tool to upload and organize subject data and images. Studios will typically import subject data at the very least to prepare for a photoshoot.
Learn more
📝 What else can the import tool do?
The import tool is very flexible and supports a variety of methods.
See more imports
What's next?
Capture and Editing
Now that a job has been setup and data has been imported, it's time to focus on preparing and executing the photoshoot - moving and grooving through capture and edit actions like:
  • Preparing photoshoot materials (QR Codes, Barcodes, etc.)
  • Preparing workstations for tethered capture
  • Capturing images with Smart Tag (tethered)
  • Sorting images with Smart Sort (QR, Metadata)
  • Reviewing Images
  • Editing Images
📢 This next module is only applicable for Smart Workflow studios.
The community largely follows a broad workflow that is broken up into 4 stages:
  1. Prepare - export slate cards; prepare workstations or equipment for a photoshoot.
  2. Execute - run the photoshoot and sync workstations - or upload and sort images.
  3. Review - audit all images to ensure all remaining, visible images are ready editing.
  4. Edit - crop, color correct, extract, etc. - get those images "order ready" for fulfillment.
Help Center
