What is a Job?
Creating a new job, exploring different options, and choosing the right mix of settings.
Think of Jobs like folders containing all subject, image, and order data for any photoshoot. Since Captura Workflow is cloud-based, all users interact with a local copy of a job, then sync to merge their changes. Users also have job tools to help preform actions like:
  • Capture
  • Import
  • Export
  • Sort
  • Print
  • and more!
Jobs have their own dashboard to review important settings and stats at-a-glance.
Create a job
Under Jobs, select New in the top-right corner to open the New Job Setup tool.
Fill out all the information on the first page to either create the job or continue the setup.
Title
Set the name of the job. 55 characters max
📢Recommend sticking to a name schema of: YEAR SEASON ORG. TYPE
Example:
  • 24-25 Spring ABC Elementary Underclass
  • 24-25 Fall ABC High School Seniors
  • 2024 Winter Jones Park Holiday Event
Type
Select a type from a pre-defined list to set to the job. Mainly used for reporting purposes.
Configuration
Enable a mix of different job configurations.
Config
On ☑️
Off ⬛
Subject*
  • Private galleries viewing assigned images.
  • Pre-orderand/orGreen Screen.
  • Captura Workflow order entry.
  • Separate subject and group images.
  • Unique codes required.
  • Keyword and/or password access optional.
  • When disabled, the job is referred to as standard.
  • One gallery showcasing all images.
  • No Pre-Order or Green Screen.
  • No Captura Workflow order entry.
  • No separation of image types.
  • Keyword and/or password access.
Pre-Order
  • Requires a Custom Form used for pre-order assignment.
  • Customers can access the shop regardless of data being uploaded into the job.
  • Customers can access the shop once images are assigned to the subject.
  • Custom Form is no longer needed.
Green Screen*
  • Price sheetneeds a background set.
  • Customers are prompted to select background when ordering a PNG image.
  • Price sheet does not need a background set.
  • PNG images are converted to JPG on upload.
Hidden
  • The job is hidden from The Shop's gallery lookup.
  • The job is searchable from The Shop's gallery lookup.
Manually Set Online Codes
  • Set your own data as the online code to access the gallery.
  • Online code is locked and randomly generated by Captura Workflow.
❗Subject and Green Screen configurations are locked after the job is created.
📢 A majority of jobs created by the community are subject and green screen jobs.
Images
Select the max quality of image to upload into the job:
  • Large Format - allows up to 6000px on the longest side.
  • Standard Format - limits quality to 3200px on the longest side.
Additionally, there's extra controls to limit images in the shop or disables face detection:
Config
On ☑️
Off ⬛
Only Show Primary Image
  • Primary images (marked with a ⭐) are the only images shown in the shop.
  • All visible images assigned to a subject are in the shop.
Disable Face Detection
  • Captura Workflow runs facial detection for every image added.
  • Captura Workflow skips facial detection for faster image ingestion.
❗Image Format and Disable Face Detection configurations are locked after an image is uploaded into the job.
Price Sheet
Set the price sheet to use for the job. Can be changed at any time.
Cart Template
Set the shopping cart template to use for the job. Can be changed at any time.
New Shopping Cart (Beta)
Set the job to use the new online ordering experience. Strongly recommended.
What other settings can I add?
The remaining sections of the New Job Setup tool are:
  • Schedule
  • Marketing
  • Order Fulfillment
  • General Settings
  • Welcome Message
  • Yearbook
  • Print Templates*
  • Export Templates*
📝 *Only with Smart Workflow
While only the first page is required to create a job, many of these remaining optional sections may be required to complete for your workflow. They're not required to create a job, however, and can be modified at any time.
Learn more
What settings should I use?
The mixed use of settings available within each section varies depending on your needs.
📝 Consider the following
Before you create a job, will the workflow require:
  • Assigning images to subjects?
  • Pre-Ordering or Proofing? Or both?
  • Extracting poses for background selection?
  • Fulfilling orders using bulk ordering or direct ship methods? or both?
  • Need any custom designs, products, or services fulfilled?
Asking those questions ⬆️
Should spark these questions ⬇️
    • Yes, and they'll need unique online codes for private access to their images.
    • No, everyone should see all organized images available for the event.
    • Do you have the necessary price sheetsfor pre-order and proofing?
      • Do you have the necessary custom forms for pre-order?
      • Do you have or plan to receive a subject data file?
      • Are there any price sheet offers or discounts to build for pre-ordering?
    • Do you have the necessary background sets created?
    • Do you have the necessary cart templates for order delivery?
    • Do you have the necessary job order fulfillment settings to match your cart?
    • Do you have the necessary designs created in My Designs?
We've jotted down a few common Job Settings configurations we've seen work for the community over the years. While most of these may apply, you may want to review a breakdown of the available settings and their behaviors.
