Creating a Testing Discount Code
Create a Testing Code
Open Shopping Cart → Create Discount Codes, then select New to create a code.
Here's an example of what creating such a code would look like:
When finished, clicking Create in the top-right corner will save and create and the code.
📝 Consider the following:
We always recommend submitting a test order before submitting orders with any custom My Designs to the lab.
Mistakes can happen in the data entry or design editing process. For any design issues that require a reprint, the affected orders need to be recreated manually.
Submitting a test order to verify the broad elements of your custom designs are correct can save the studio some major costs if anything feels rushed.
Try adding an expiration date to prevent any internal codes from remaining dormant and unexpectedly used.
