Selecting Yearbook Pose(s) in the Shop
Selecting a Yearbook post in The Shop
To select your Yearbook Pose while placing an order, you can do that right from the shopping cart—super easy!
Here’s how:
  1. Log in to the online gallery using your access code or link.
  2. Add your favorite image(s) to the cart and begin the checkout process.
  3. Look for a section labeled "Yearbook Pose Selection" in the shopping cart or something similar (usually on the left or near your image previews).
  4. You’ll see an option to choose 1 or 2 images (depending on what the studio allows) as your official Yearbook Pose(s).
  5. Once you’ve selected your image(s), continue checking out—your pose selection will be recorded with your order!
If there’s a deadline for pose selection, make sure to choose before that date so your image is included in the yearbook!
https://onboarding.imagequix.com/en/articles/9830720-yearbook-selection-image-attributes
