What is a User Role?
A role is pre-defined set of permissions in Captura Workflow. The user with that user role will have access to the data, features, and tools as specified in the role. With roles, studios can define the data, features, and tools needed to perform job duties like:
📢Every studio has an Admin role by default that has app-wide access.
Smart Workflow members enjoy immediate access to User Role templates that we recommend as a great starting point for any studio. They're pre-built roles that enable you to get started faster or use them as a starting point to update or duplicate as needed.
Create a new user role
In Captura Workflow, open Preferences, select Roles & Permissions.
You can select Add Role to create a new role or duplicate an existing one to start with.
âť—Smart Workflow studios have additional permissions to customize that are specific to the features and tools included with that membership.
When finished, click Create to save your role.
We've complied a separate article that runs through the different permission levels available and what each feature controls.
Using a Role
In Preferences, open Users and select an existing user or create new one.
When modifying a user account, click on the drop-down under Roles and Permissions to attach one or more roles to a user.
If more than one role is attached, Captura Workflow will mix the permissions to for blended access. This means the user account will always have the highest permission-level for anything in Captura Workflow available to any of the used roles.
âť—Trouble logging into Captura Workflow?
While you can create users and assign roles later, it's important that a user has at least 1 role assigned before login. You may see a weird screen and require assistance to get unblocked.
